bellamyr
fx401 memory upgrade
Hi
I have an fx401 that still looks to be going strong despite a broken battery. I want to upgrade the memory in it. The official spec says that 512MB is the most you can fit but I have seen 512MB 200pin PC133 SO-DIMMS avaiable which should take it up to 1Gig. Does anyone know if these will work?
Many thanks
Richard
Thalamus.
Champion
Hi bellamyr,
Welcome to club vaio, :slight_smile:
Unfortunately no the maximum RAM is 512MB... :slight_frown:
I also think a 256MB module is the maximum your vaio will accept...:smileywink:
bellamyr
Quick response.
Thank very much. I'll spend the extra cash on a bigger disk instead. I also have a CPU I need to drop in.
Thanks again
Richard
Thalamus.
Champion
You're welcome Richard, :slight_smile:
