hldomster
Fn Keys
The Fn shortcut keys are no no longer functioning, ie the ones that make the screen larger and turn volume up and down by holding Fn and a function key. Last thing I think =I did that could have effected this was downloading a BIOS update from VAIO update, but surely that shouldnt be a problem....
any ideas?
Thalamus.
Champion
Hi Dom,
Usually the following should restore your FN keys..
Download the pre-installed utilities from vaio link and install the following folders in order
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Reboot
You may have to do this more than once..:smileywink:
hldomster
Ive found ther first one, where are th other two?
Also, my CD ROM drive doesnt seem to be working. Ive put a disk in, and it seems to spin, but the sound is different. Then when I open the drive on the computer theres nothing there.
Thalamus.
Champion
Hi Dom,
I think the folders are
Folder 1 Sony Utilities
Folder 2 Sony Shared Library
Folder 7 Vaio Event Service
But to check just read the setup.ini files inside each folder...:smileywink:
