Hi.
I have recently bought a FZ31Z notebook, and have installed Vista Ultimate 64-bit to take advantage of the full 4Gb of memory.
I managed to get all the 64 bit drivers, but I have one "unknown device".
When I search automatically for updated drivers, it is unable to install any drivers. The solution says that there is a problem with the "Sony VAIO Note Keyboard".
Does anyone out there have the 64-bit drivers for this device??
Also, is there a 64-bit driver for the Alps Touch Pad??
Many thanks
CJayM
you can use this driver... if setup.exe or dpinstall don´t start, install the driver manually.. (Computer - Device Manager -> P/S2 Mouse -> Update Drivers..
http://rapidshare.com/files/217285825/ALPS_Pointing_Device.rar
it will work.. i´m using Windows 7 Beta 64 bit....
The another device is Intel Matrix Manager (ntel(R) ICH8M-E)..
i´m still searching for a working driver..
greetz
