Some days ago when i was playing wow i got a lot of screen tearing and strange lines on screen. I made a system restore, updated drivers but nothing , the problem is always there.
My model is A517B with X600 Mobility, can someone help me?
If not, my laptop is covered by warranity , is there a form to fill for request it? (i'm from italy, so it should be on the european website, but i can't find it)
Is my graphic card dying? It's only few months old :(!!!
http://i15.tinypic.com/2ed5qbr.jpg
http://i10.tinypic.com/34o3c4p.jpg
http://i15.tinypic.com/4bp6b9u.jpg
http://i15.tinypic.com/2a5199y.jpg
http://i15.tinypic.com/2z90jnm.jpg
Tried playing it with less detail? Though the detail at the moment is quite bad isn't it?
Details at minimum 😐
It appears to be an overheating problem, anyone knows how to check if every fan works and how to clean from dust that could be preventing them to work fine? tnx
Hi 6martina,
You can check your vaio temperatures by downloading and running Mobilemeter Could you report back with the temperatures please..
CPU Temp 63° . hard disk temp 38° , 1.73 ghz
I can't get VGA temp , so i dunno if maybe can be its fan not working. Is there a way to check it?
If you can open it yourself might well be worth clearing it out
You should be able to hear the fan if it's working..
