Green liquid on the adapter !!!
AlinFM
Sorry for stealing these pictures from a previous post :
http://imgur.com/FELw3
http://imgur.com/P80xH
http://imgur.com/xd9F9
But I experienced exactly the same problem today with my laptop, which is basically almost the same model as the one in the pictures. I couldn't find what the solution was in that post. Can anyone help me please ? What could this be and where did this liquid came from, the adapter, or the laptop ? Cause i can't figure it out. Could i damage  my laptop if i charge it like this ?
Here is the previous post : http://community.sony.co.uk/t5/pcs-accessories/green-liquid-on-the-adapter/td-p/366421
rich912
Hi AlinFM,
Kostij contacted support who arranged to have the adaptor replaced. As we have not heard anything further I assume that solved the problem.
I suggest you contact support and refer them to that thread.
Rich
Go n-éirí an bóthar leat
