i have a sony vaio FR315m which has a 40 GB harddrive
what is the largest harddrive i can replace this with
How deep is your pocket?
As long as you have XP SP2 and your laptop is reasonably new any suitably sized HDD (physical dimensions) will be fine.
Don't forget speed is everything and upgrading to a 7200rpm drive will give you a more of a noticeable speed increase than a processor upgrade.
The biggest HD for laptops is around 120GB now
