Hi guys, I have two accounts in my sony vaio(laptop). By mistake I've changed both of them to standard user. Now the computer won't allow me to make a simple change. I need to change one of them to admin again. But have no idea. Any suggestions would be great......
Thanks,
Pav
That's a bad spot but there are workaround on this. What OS are you using?
Try booting up to safe mode and check if there is an admin account available.
Also, alast resort here is to reload the OS using the recovery partiotion. I'm not sure if its F9,F10 or F11 here. Make sure you back your files before doing this. Good luck.
