So when you have problems with this knocking noise of the HD you need to go to sony to repair it?
Opening up the laptop and doing it yourself will mean you lose warranty?
If you dismantle the notebook then (if they can tell) your warranty will be invalid.
Some models of hard disk do make a tapping noise and this doesn't necessarily indicate a fault.
Why should you do it by yourself if your laptop is still under warranty?
Not having to miss my laptop for i guess 2 weeks....
Rob's right, this might be it's usual operating sound
It's just a single short knock and it's frequence varies but it's quite hard...
Sounds like parking to me
It could be a small Sony engineer stuck inside the casing?
