Hi I have the VGN-FS215E and every time I plug headphones or external speakers in the socket on the front I have to spend a long time wiggling the wire just trying to get sound to come out, it crackles and buzzes. The problem it now sometimes does this on the internal speakers, if you lean to hard or have put it down with a jerk then crackles and buzzes then. Has anyone else had this problem?
If so could you please reply or e-mail with how one might be able to stop this problem.
Kind Regard,
Ben Freakley
ben.freakley@brierleylodge.co.uk
Is the plastic around the phones socket cracked
