Help!!! AR41L Recovery Problems
deathcollector
erm i have a sony VGN-AR41L,
basically i had a dual os on my harddrive of linux and vista,
and the defualt boot manager was the linux one...
I set up a factory reset everything went okay until it restarted the defualt boot loader was the linux one and now i cannot boot into the original OS of vista, as the laptop didnt come with recovery CD's i dont know what to do...
Is there any way to change the boot loader back to its default one..... the VIsta one without having to acess the os ?
Any other solutions
Thanks for your help
profile.country.pt_PT.title
V57...
Hi deathcollector:
Another solution...you may delete the partition that has the linux...
