Help. I have lost my DVD drive!!
itu-nurse
Can anyone shed any light on this. I used vaio update after which my system crashed. I used system restore to get it up and running again, using the setting from before the update. This works fine, however, the computer no longer sees my optical drive. The drive works fine in safe mode.
It does not show up in 'My Computer' and I can not run any discs from it.
All hep appriciated.
Julie
UK
25 REPLIES 25
blue1901
Julie,
in any hardware/device problems, the only solution is to recover your PC. just copy everything to your MP3 player or blank DVDs then format and recover everything, everything will be ok, the DVD drive and the TV prog.
rich912
This is not the case at all, Blue 1901, there is usually a far more simple, and less time consuming solution – if you know what you are doing.
Go n-éirí an bóthar leat
blue1901
Look kid.
i am offering my solution, to transfer ur files to a network walkman means i obviously know "what im doin"!
This is the ONLY solution.
profile.country.fr_FR.title
@2213977901016847
No, The solutions there is always full!
Non, Les solutions il y en a toujours plein !
blue1901
ok! So tell me!
my VAIO doesnt allow me to create recovery disks, it says restart the PC and destroy the CD, how can i fix this?
robpaxton
Copy all your stuff to a network walkman and recover your PC.
blue1901
OF COURSE! that's what i said but "tvesin" thinks we don't know what we are doing!!
@2213977901016847
Mais non ! vous savez ce que vous faites !
blue1901
tvesin,
pas de probleme!
Do u have VAIO VGC-V2M? is it good?
@2213977901016847
tvesin,
pas de probleme!
oh yes
