Hello the laptop I have is currently 5 months old and its vpceh2p0e but sometimes when I plug in my ac adapter I recieve the message "Plugged in not charging", I would have to remove ac adapter then plugged it back in and it works. I tried checking if everything is secured cable connection and the battery is not loose.
In order to correct problems with the battery's power management software, follow the steps below.
1. Click Start and type device in the search field, then select Device Manager .
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
for more information http://forums.cnet.com/7723-19681_102-345945/plugged-in-not-charging/
_______________
Life is too serious to be taken seriously
