HELP!!! MY SONY LAPTOP KEEPS SHUTTING DOWN
Peteri
Hello,
My VGN-FJ3S/W keeps on shutting down a few minutes after it's been turned on! Why is this? and how do I fix it??? Can anyone help??
I was running vista on it, and decided to go back to xp, cus too much stuff wouldnt work. Now that xp is up again, it keeps shutting itself off. Just like that, no 'windows is shutting down' it just switches off. When I turn it on it starts up like nothing's wrong.
It gets really hot aswell, but this was never a problem before, when I upgraded to vista, the overheating stopped. But now its come back,
Again: Does anyone know what the problem is and how I can fix it????
Peter
23 REPLIES 23
rich912
Hi Peter,
It would seem that overheating is causing the shutdown. I suggest that you download MobileMeter and let us know the CPU temperature.
Overheating is usually caused by a build up of dust in the cooling vents and can often be cured by using compressed air to clear the vents.
Go n-éirí an bóthar leat
Peteri
Thanks for your trouble
I left it off all day yesterday and turned it on this morning right now the tempereture is 68 degrees celcius now 76. whats does this mean?? also i noticed man fans not on.
What next?
Peter
rich912
Hi Peter,
Those temperatures confirm that you have an overheating problem and that is why your machine is shutting down.
Assuming that the fan is no longer audible then either it has failed or something is preventing it from spinning. I suggest that in the first instance you buy a can of compressed air (sometimes branded as an ‘Air Duster’) and, holding the can upright, direct several jets of air at the cooling vent from a distance of about 100mm away.
If this has no effect then the notebook will have to be disassembled for investigation. :slight_frown:
Peteri
Okay,
So where can I get a can of this 'air duster'?
Thanks again
Peter
kee-lo_
100mm is 4 inches for the imperialists
Thalamus.
Champion
Okay,
Thanks again
Peter
Maplins stock Air dusters .. :wink:
Peteri
Okay, thanks guys for all your support
will hit maplins asap and cop' me a can of that air duster.
Merci beaucoup
Peter
Thalamus.
Champion
Let us know the results after using the air duster.. :slight_smile:
apierc1
The cheapest Air Duster I have found so far is from Staples, Fellows, £5.89 I think, equivilant can in PC World is over £10 :slight_smile:
