Hi can a full instale off windows 7 be done ok and are all the drivers to run it out there on the download site
Sony provide Windows 7 drivers for your AW11 here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AW11Z_B&os=10
If a Windows 7 driver is not listed here (some are not listed for Windows 7) then you will need to install the existing Vista driver.
You will find an UPGRADE installation easier as this is the only way to keep your existing preinstalled software like WinDVD BD and others. If you make a clean install you will lose this software which cannot be downloaded and you will need to buy replacements.
