Help with Sony Vaio VGN-SZ3XWP/C
Storm924
Hi, I was wondering if someone could help, I have a  Sony Vaio VGN-SZ3XWP/C and the hard drive has died. I've replaced the hard drive but i can't find the recovery cd's i made when i first got the machine. Is there any way to download or get a copy of the recovery cd's?
Thanks for your help.
You can buy a replacement set of Recovery Discs from Vaio Support.
Go here and enter your Vaio's Serial Number: -
http://support.vaio.sony.eu/computing/vaio/index.aspx?m=0&l=en_GB
You will find the contact options under 'Get in Touch'.  Unfortunately, as you are out of warranty, you will need to use the premium out-of-warranty support number @35p/min.  The number from the UK is 0905 0310006
:wink:
:wink:
