Help with vaio sve 1511m1eb model
Nancy23670
Hi ,new laptop ,can't get past set up ,error box on screen ( computer restarted unexpectedly or encountered a error .windows installation cannot proceed ,to install windows  click ok to restart computer then then restart the installation  ).      I have done this several times but after laptop restarts this error box reappears  so I can't get to the installation part can anyone help
Kind regards nancy
Hi Nancy and welcome.
Have you bought the Vaio in a store or online?
If you bought it in a shop, I think I would take it back and ask for a replacement.
If you have bought the Vaio online then it is probably worth trying to do a full system recovery first to see if that helps.
To Recover from the Recovery Area: -
1.  Press the ASSIST key when the Vaio is TURNED OFF.  This will start Vaio Care Rescue.
2.  If you are asked to choose a language, select your language and click OK.
3.  Click 'Start Recovery Wizard'
4.  Follow the on-screen instructions for a complete recovery.
Make sure your Vaio is connected to the AC supply and leave it until it finishes - it may take some hours.
Come back if you have further problems.
:thinking:
