Totally fed up with sony laptops. I wonder if anyone could help to solve problem with my sony vaio (VPCEB1E0E). Since Feburary it takes ages to load to startup and even after that it keeps freezing in between while operating.I'm not runing any such programs even there are not a lot programs downloaded. Earlier I thought that it is due to anti virus program (Norton) I uninstall that and put Kaspersky internet security 2011 as I thought there was virus but I scanned it with Kaspersky but it came out with nothing. Any idea why does it doing this behaviour and how I can resolve this issue ? And battery icon also missing as well.
Thanks for responding, in advance. Any help will be much appreciated!!!
Garhwal
Easiest thing to do is a full system recovery using the Sony Recovery Tool
This will reset the laptop to factory condition but you will have to make sure you back up all your docs first since the whole hard drive will be wiped clean
Once you have done this it should run normally
If it still freezes and is slow you may need to post some more details of what the precise problem is
Good luck
hi peshyxp,
thanksa tone for quick response. one thing i ask prior, didn't create recovry and back up. Will sony recovery tool will work?
what updates I did earlier for windows and vaio will I have to do again ?
