Help!
profile.country.uk_UA.title
Hudorkov
Help!
please help me find the drivers (graphics) on a laptop SONY PSG-955C
rich912
Hi Hudorkov,
You are quoting an invalid model number. Have a look on the screen surround or above the keyboard. You may find that it is a PCG-FX101 – if so you will find the drivers here:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=PCG-FX101
Rich
Go n-éirí an bóthar leat
rich912
Hi Hudorkov,
Rich
