Hi
First of all I am sorry if I am asking a stupid question but I am not really good at this computer thing
I am using a Vaio VPCF23ZE1. Today I downloaded Heroes Might and Magic VI and I wanted to play it with max quality settings but I couldn't because it is freezing during the cinematics and gameplay. I checked the recommended system requirements list on the web and here what it says;
Minimum System Requirements: | Recommended System Requirements: |
CPU: | Intel Pentium Core 2 Duo E4400 @ 2.0 Ghz, AMD Athlon X2 5000+ @ 2.6 Ghz | CPU: | Intel Pentium Core 2 @ Duo E6400 @ 2.13 Ghz, AMD Athlon II X2 240 @ 2.8 Ghz |
RAM: | 1 GB for Windows XP and 1.5GB for Vista / Windows 7 | RAM: | 2 GB |
VGA: | 512 MB, DirectX 9.0c NVidia GeForce 8600GTS, ATI Radeon HD 2600XT, both with 512MB of VRAM - Minimum 512 MB of Video RAM - Vertex Shader 3.0 - Pixel Shader 3.0 - Vertex Texture support with R32F or R16F format - Render Target support with R32F and G16R16F format | VGA: | 1 GB, DirectX 9.0c NVidia GeForce 8800GTX, ATI Radeon HD 3870 both with 1 GB of VRAM - 1 GB of Video RAM - Vertex Shader 3.0 - Pixel Shader 3.0 - Vertex Texture support with R32F or R16F format - Render Target support with R32F and G16R16F format |
DX: | DirectX® version DirectX 9.0c 2008 November (included on disc) | DX: | DirectX® version DirectX 9.0c 2008 November (included on disc) |
OS: | Windows XP, Windows Vista, Windows 7 (all 32/64 bit) | OS: | Windows XP, Windows Vista, Windows 7 (all 32/64 bit) |
http://gamesystemrequirements.com/ |
HDD: | 8 GB | HDD: | 8 GB |
Sound: | DirectX 9.0c compatible | Sound: | DirectX 9.0c compatible |
ODD: | DVD 8x (DVD 24x), needed only for installation | ODD: | DVD 8x (DVD 24x), needed only for installation |
Network: | 128 kBit/s upstream | Network: | 128 kBit/s upstream |
I wonder if the problem is about my graphic card or might my vaio be working slow due to another problem such as a virus or something else..?
by the way VPCF23Z1E is using NVIDIA® GeForce® GT 540M GPU. I tried to compare GeForce 8800GTX and ATI Radeon HD 3870 with my graphic card but memory clock shader clock memory bus type blaa bla.. I don't get it 😕 Can anybody tell me the truth?
Thanks for your help!
Hi ninozig,
I'm not a gamer so probably not the best person to answer your question, but I suggest that you try the following link.
http://www.systemrequirementslab.com/cyri/
Rich
