My Vaio VPCEB4C5E Overheating When Playing Games!!!
djlevan
Hey Guys,
My Vaio VPCEB4C5E ovearheating and then shut down when it exceed 90 degree,
For instance, if i play PES 2013, PES 2012, does not matter, after one hour it starts terrible fan noise and then shut down automatically, I have just installed ASSASSIN CREED 3 and still overheating and shut down after 30 minutes, How this can be solved?
It's clear there is something wrong with fan or video card, i don't know,Please suggest me
Thanks in advance
Levan
rich912
Hi djevan,
I suggest that you start by cleaning the cooling vents with compressed air (Air Duster). You can purchase an ‘Air Duster’ from your local PC shop or even larger supermarkets. Be sure to follow any instructions on the can – in particular hold the can upright and at a distance of approx. 100mm from the vents.
If this doesn’t solve the problem then disassembly may be required for a thorough clean of the fan and ducts.
Rich
Go n-éirí an bóthar leat
djlevan
Thanks for your response, Mate, I will try and let you know
It may be better idea if i take it into SONY REPAIR SERVICE< so actually they can check inside
