Hi all, can anyone tell me how to pair my phone with computer? or turn on bluetooth on computer????
profile.country.en_IE.title
defenceforce
can anyone tell me how to pair my phone with computer? or turn on bluetooth on my computer???
Hi John,
Unfortunately your Vaio does not have Bluetooth included - have a look at the full specifications here: -
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?m=VPCEB1M0E_WI&l=en_GB
I'm afraid you will have to splash out on a Bluetooth dongle that fits into your USB port - something like this one: -
http://www.amazon.co.uk/Belkin-Bluetooth-plus-Adapter-range/dp/B001BRV7JE/ref=pd_cp_computers_2
Or this one: -
http://www.amazon.co.uk/Belkin-Mini-Bluetooth-Adapter-Class/dp/B001BROKXO/ref=sr_1_1?ie=UTF8&qid=130...
Good Luck
:slight_frown:
4 REPLIES 4
What model Vaio do you have?
What phone do you have?
Not all Vaio models have a bluetooth capability.
:thinking:
defenceforce
Hi , my sony vaio is VPCEB1MOE, if that make sense? my phone is a NokiaE5, thanks for getting back to me....
kind regards
john.
Hi John,
Or this one: -
Good Luck
:slight_frown:
defenceforce
Blencogo hi, Thanks for info realy helpful I taught I was loosing it not being able to get it working? anyway thanks again have a good day....
Regards
John.:smileycry:
