How do i use motion eye?
profile.country.sv_SE.title
edvinaks
Hi, i have a computer model: VGN-TZ11XN B, with Win 7. I've been trying to use the motion eye to take pictures. But i can't find a driver that match the model. I'm lost. What should i do?
Tags (3)
5 REPLIES 5
The Vista Driver and Capture Utility should work OK.
Download and install: -
1. VCC7 Camera Driver from the Original Drivers Package
2. Vaio Camera Utility from the Original Utilities Package
3. Vaio Camera Capture Utility from the Original Utilities Package
Download these packages from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-TZ11XN_B
:wink:
edvinaks
thanks! I've done that now. But how do i use the camera? Forgive me if i sound stupid, but isn't there a program of some sort, like i don't know, photobooth?
rich912
Do you have a folder named ArcSoft WebCam Companion listed under Start All programs?
If so open ‘WebCam Companion which will be in that folder...
You can also use the motion eye camera with programs such as Skype and Live Messenger.
Go n-éirí an bóthar leat
If you don't have the Arcsoft Program then try opening 'Vaio Camera Capture Utility'.
:wink:
edvinaks
I have neither. Is that odd? Can i download those programs somewhere?
