How can I get an Installation Disk?
johcamac
My Vaio has a Boot configuration data error.
File:\Boot\BCD
Status: 0xc000014c
I need an Installation Disk
What can I do?
mithcd
Hi. Mostly, notebooks have a hidden partition and you can do a system recovery on boot up. What model is this? https://imagicon.info/cat/12-13/vmware_happy.gif
rich912
Hi johcamac,
There are a few suggestions in the following link that may help:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-networking/file-bootbcd-status-0xc000...
You can download a Windows repair disk from here (there is a small charge):
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
Or you can create a repair disk on another computer with the same OS:
http://www.howtogeek.com/howto/windows-vista/how-to-make-a-windows-vista-repair-disk-if-you-dont-hav...
If you need Sony Recovery Disks to return your machine to factory settings you will need to contact Support. Alternatively tap F10 at boot to enter the HDD recovery utility. A reset to factory default will wipe all personal data and third party programmes.
Rich
Go n-éirí an bóthar leat
rich912
There seems to be a echo on this forum...
