How do I alter the burn speed on my cd/dvd rom drive
vernonfowler
Hi
How do I alter the burn speed on my cd/dvd drive
vernonfowler
For most versions of WMP, try the following: -
Start -> All Programs -> Windows Media Player
Player Library -> Burn Tab -> Burn Options -> More Burn Options
You should find a few burning options including Burn Speed.
:thinking:
4 REPLIES 4
What software are you using to burn the discs?
Burn speed is usually automatic but the software - WMP, Nero, Roxio - will usually allow you to change burn speed.
:thinking:
vernonfowler
Hi Blencogo,
I am using Windows Media Centre
vernonfowler
:thinking:
vernonfowler
HI,
Thank you, there were no "burn options" but there was a small drop down box that revealed "more burn options,and that did the trick. Thanks again!
Vernon
