how do i burn a dvd from my vhs recorder?
depanch41
hi,
i have an ar41L, is there a way for me to write a dvd, using my vhs recorder as input? (e.g. copy a film on vhs tape, to a dvd)
thanks.
tonybeard
Sure is a breeze. What you need a is a Dazzle Digital Video Creator here which comes with brilliant software called Pinnacle Studio. You won't drop any frames with that grunty processor. Might be a good idea to check PC World and pick from store it may be cheaper. :wink:
kee-lo_
I would hold out a bit, as freeview HD is on the way, and some good Haupagge systems are due soon which will do what you want it to do, and give you access to the forthcoming BBC HD freeview service, alongside the possability of getting 4HD
