How do I burn images to blu-ray with VGN-FW51ZF?
notdarkyet
I've searched all through my software and can't find anything to do this!  The standard Windows Explorer doesn't want to know, although the drive is recognsied and it says I have files waiting to be burned.  Please help!  Thanks 🙂
Hi notdarkyet and welcome.
Is the preinstalled Roxio Easy Media Creator 10 the blu-ray version?
I think Premier Elements 7 supports BD burning.
:thinking:
profile.country.fr_FR.title
hadermo
Hello,
i m sorry for disturbing you, but i have i ''big'' problem with the TV of my VGC-V2M.
the problem is that my XP system was broken down and i was forced to re install my system, i ve installed all the drivers inculding the Vaio Zone Launcher but i can t found the TV icon anymore i installed a lot of drivers of TV encoder and TV softs but no result.
on my Configuration pannel i have this in yellow '' ! '' AverMedia AVerTV Video Encoder Capture (M113)
And this is my Computer Configuration : Xp professional SP3   3.00GHz    512 Mo RAM
Thank you in advance
i really need to solove this problem cause this computer is not mien and it belongs to somone hwo use the fonction of TV all the time
Thank you
Email: Hader.mohamed@gmail.com
Message was edited by: hadermo
