Hi Guys
I have an F Series Vaio that's about 2 years old.
Recently the hard drive went boom so I had a new one installed.
I then used the recovery discs to get my laptop working again.
I did the usual first steps with user name etc on Windows and connected to the wifi.
I then closed the lid to take it to another room.
When I reopenned the lid the graphic resolution had gone crazy. The pointer and the icons were massive.
I tried to change them in the desktop Preferences but they still looked dull and in no way HD like they should on the LCD screen. The screen is called a non descript PHP rather than my HD one as well.
There seems to be now 64-bit options on the different modes you can pick and when I ran a Microsoft test on the laptop it scored 1.0 on Graphics and gaming and screen res.
I presume it's just loaded a 32-bit version or I can use the repair option through BIOS???
Any one had this or have any ideas?
Hi rybyron,
You haven’t stated the full model number so unable to give a full link, but have you tried installing any updated graphics drivers available on the support site?
http://www.sony.co.uk/support/en
Rich
Yeah sorry man.
I posted this from work so don't have the number on me.
I'll give that a try.
