How do I get hibernate to work again?
87068278
I have a Sony VAIO laptop which has been great but recently has started to freeze after I try to bring it out of hibernation.  Sometimes it starts after 5-10 minutes sometimes it just goesa to a black screen.  I have to hold the start button down to force a switchoff and then start it again.  Laptop is a VPCEB1E0E.
rich912
Hi 87068278,
Amongst other things  this can be caused by the graphics driver or third party software. I notice that there is an updated Intel graphics driver 8.15.10.2040 available from the support site. If you haven’t already done so I suggest that you first try installing this.
http://www.sony.co.uk/support/en/product/VPCEB1E0E_T/downloads/EP0000219982_5011
If you have already have this driver installed or that makes no difference then try a selective startup to try eliminating any third party software or service as the cause.
http://windows.microsoft.com/en-us/windows-vista/Run-Selective-Startup-using-System-Configuration?Si...
Rich
Go n-éirí an bóthar leat
rich912
Hi 87068278,
Rich
