Can anyone help? I just got a new Sony Vaio and have deleted the internet explorer icon by mistake from the vaio gate. How do I restore it, and how do I add new icons? Would really appreciate any help!
You can drag and drop a shortcut to the Vaio Gate area.
You need to open Explorer (Right-click on the START button -> Explore) and find the .EXE file that opens the program.
For example, if you have lost the Internet Explorer icon, go to C:\Program Files\Internet Explorer\iExplore.EXE
Right-click on this .EXE file and choose 'Create Shortcut'
Drag the new shortcut created into the Vaio Gate area and it should stick there.
it does not work on me
Even I can not find vaio gate.xml file in
C:\Users\Users\AppData\Roaming\Sony Corporation\VAIO Gate
how to solve this problem?
I have tried to do drag and drop
when I drop the shortcut which I have made, nothing is happen
