I need install Windows Xp on AR61MR, but i can't find drivers for windows XP . Help me ,please !
Hi PhamQuang,
welcome to Club Vaio..
It is possible to install XP on your vaio but beware Sony will only support Vista on your vaio therefore if have a problem with your Vaio and you need to contact vaio-link you will probably have to reinstall Vista, also you will loose all of the applications that came pre-installed on your Vaio..
If I where you I would try and stick with vista..
However if your sure that's the route you want to take, have a look at Blencogo's post in the thread using the following link: XP Drivers for VGN-AR61E
And you may find these thread of interest..
Full instructions to downgrade an AR31M from Vista to XP Pro
Audio drivers for downgrading to xp on AR51M
