- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
How to access the AT-Key
On my Vario the At-Key is on the 2-Key, but I don`t know how to access it. I tried about every key-combination I can think of. Normally, it should be ALT GR plus the 2-Key, but that does`t work. Who can help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi dfaltin and welcome to the forum
You are correct that it should be ALT GR plus the 2-Key. If that is not working are you sure that the keyboard is configured correctly for your country?
Go to Control Panel > Regional and Language Options > Languages > Details. Click on keyboard > Add. Check the keyboard layout box and select the country of your choice (to match your keyboard layout ). Click OK and then, under Settings > Default Input Language select that language from the drop down menu and click OK.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks!!! problem solved.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi dfaltin,
Good to hear that the problem is sorted
