how to deinstall My Club Vaio
Dalma
My Sony Vaio C, automatically starts My Club Vaio when Vista starts up..
I checked under installed applications, and msconfig but can't find a way to deinstall or at least cancel the automatic startup of my club vaio?
Anyone who can help?
27 REPLIES 27
Thalamus.
Champion
Hi Dalma,
You are unfortunately not alone with your problem, have a look at these threads Here and here... :slight_frown:
Dalma
unbelievable..
The program is stored under : C:\ProgramData\Sony\MyClubVAIO
There are some vbscript files like deletelauncher etc etc..but don't exactly what it does.
Thalamus.
Champion
Hi Dalma,
There does not appear to be a un-installer for MyClubVaio.exe... :slight_frown:
wshand4
Hello,
I just thought i would let people know how to stop this showing up, view Microsofts Task Schedualer, i deleted the task and now its fine
BTW i use Vista :wink:
Hi wshand4.
Welcome to Club Vaio.
Thanks for the tip - that should stop a lot of frustration!!
:slight_smile:
RicardoBathUK
Thanks wshan04, it worked!! I had 4 reminders as tasks ti register in there!!
Only issue now is the Task manager says it is corrupt or been tampered with!! Any idea how I fix it?
Thanks for sorting out the club vaio start issue!
Richard
thevinster
Hello,
Doh! Why didn't I think of that! Well, no matter... I'm glad you did! I also noticed that it was set to expire on the 12th of May 2007. Sounds like a very poorly implemented Sony marketing tactic.
Note to Sony: You should have made it easier to disable the reminder... otherwise it gets REALLY annoying!
Thanks very much for the tip!
Dalma
Hello,
Hi, great thanks for the tip. ROFLMAO..funny i didn't think of that..
Btw do you know what the reminders mean: MCVSurveyReminder1 (2,3 and 4)?
Did you delete this as well?
Thanks in advance!
pippo561
Thank you for that WSHAND4, very easy. I just disabled it, no errors and processor settles down to minimum very quickly
