eveything is in the title...
I have a vaio C2Z running on vista, i find it quite annoying not to be able to know how much time do I have left to run my vaio on battery alone
anyone knows a solution ?
THANKS !!
Masaki
Hi Masaki,
Unfortunately Sony Vaio's only display the % remaining..
There are applications available, something like battery mate, that can predict the remaining battery time available. I can't say how accurate they would be though as I have never used one..
Thal, I get time display on both my A317S and T2XP. Don't know how, it's just there.
