There's a red screen error that shows up on the screen in different languages. I want to know if there is a fix for this. And no calling Sony isn't an option because I'm not covered by warranty so don't suggest that. I accessed the recovery menu and am not able to rebuild the database or restore the file system. What is a good method for fixing this.
Solved! Go to Solution.
hold the ps3s power button untill you hear two beeps and let go and the re configure the hdmi option in the boot menu and it will be fixed ...
Hi isiri12
For Playstation problems your best bet would be to post your question in the Playstation forum (link), hopefully someone will be able to help..:smileyhappy:
