hi,
i just have a PCG-K415S notebook whit a P4 532 533Mhz frontside bus processor,and when i read the cpu specification paper that came whith the vaio :
support Enhanced intel SpeedStep Technology and Hyper-Threading
Now the problem is that when i run PCMARK ( pc performance Analysis) it sais that Hyper-Threading is Available but Disabled !
Is there a way to check that hyper-threaing is enabled in win XP home with sp2 ?
Thnx and regards
Does the "intel inside" sticker on the laptop have a small HT on the right hand side? See
here.
Some processors which are HT-enabled dont have the benefits of HT technology because you also need a compatible motherboard/chipset. This may only need a BIOS upgrade.
When HT is enabled the device manager should show 2 processors.:smileygrin: :smileygrin:
Interestingly, Sony said in my info sheet with the K115Z that it has enhanced speedstep -well it doesnt and never will have. It only has Speedstep, so I think they are confused...
The difference is with enhanced speedstep the processor voltage and frequency change across a wide range, while speedstep simply changes the frequency from 3.06Ghz to 1.6GHz only.
Hi, the sticker have no HT marks so no ,hyper-threading and yes the crew who made the info sheet problely where drunk
cu and thx
It looks like the PC doesn't have HT.
PCMark usually is very accurate.
I would have a word with Sony, as it's been sold to you under the wrong pretence.
Yeah and using Everest Home Edition too.
Forgot about that one.
if you see two process then it has HT
Next to the graph Chris
