Hello, I've recently bought a Vaio (VPCEH3L1E). I've made a fresh windows installation. When it came, on it's opperating system I had some applications like PS3 remote keyboard or Vaio media gallery. Which is the place to download them back? On laptop's download page i couldn't find anything about them.
Solved! Go to Solution.
Hi foravis,
Due to licensing restrictions most of the pre-installed software is not offered for download. If any are available they will be obtainable from the following link. Otherwise only updates will be listed which will require the original software to be installed.
http://www.sony.co.uk/support/en/product/VPCEH3L1E_B/updates
The only way to retain the original preinstalled software is to reinstall the original OS and then carry out an ‘in place’ upgrade – assuming that the version of windows you have purchased will allow this.
Rich
Hi foravis,
Rich
I've thought it was some restrictions but i've hoped it can be done through Vaio Update or something. Thanks anyway.
