I CANNOT BELIEVE THIS!!
Robby41
I am due to set off to Cardiff at 4.30am tomorrow and i went to add some music to my VP and forgot to stop playing a track and automatically hooked i up to my PC to find the thing had crashed, this has happened before and has turned off after about an hour but in this case i have just charged it fully so i does not seem likely that i am going to be taking my VP as it only has 5 hours to turn itself off, and the battery lasts for 20 hours.:smileycry: :slight_frown:
What i want to know is there any chance i can make it turn off straight away, in fact i am so desparate i am contenplating opening the thing up and removing the battery and puttin it back in.
So you's with VP's that batteries seem to go quickly count yourselves lucky.
5 REPLIES 5
RubenBCN
It happened to me once that i didn't know abaout the reste button so my VP hanged and I removed the battery. All worked fine later.
Now, I use the reset button... It happened like 2 - 3 times in 5 months, near where you connect to the base.
You have to use something very thin.
Robby41
Yep, I have just done that and it works fine now!
I also think i have solved the reason why it keeps crashing in the 1st place because the casing over the battery was slightly loose and where the wires connect to the circuit board i simply clicked it fully into place :slight_smile: so much for quality check from sony. and i am still unsure on the reset button.
Where it is exactly ,,in more detail whats does it look like?
And waht happens when i reset it? do i lose any files or data?
hldomster
No, you wont lose any files whatsoever. The switch is located underneath the VP on the narrow side opposite the power switch. It is a small hole that you will need to push a pin in to activate the switch. You will need to reset the time etc. after doing this, but your music files are safe. This normally solves any problems I have with my VP. If you still cant find the switch then look at the quick start guide, as it shows you in there.
I hope youre not going to Cardiff for the match. I bet your a manc supporter too. I'm a Newcastle season ticket holder and I think we'll get thrashed, and so does everybody else up here. Never mind. Enjoy.
Robby41
Yep!! I am GEORDIE from SOUTH SHIELDS!
On my way to Cardiff to see us beat the manc's
Come on the TOON!
hldomster
Thats the spirit, howay the toon!!!
