aNY HINTS ON HOW I RE-INSTALL IT WITHOUT GETTIN A COMPUTER GUY TO FIX IT EXPENSIVELY. y CAN STILL PLAT DVDS. PLEASE HELP
Solved! Go to Solution.
If you have deleted WinDVD BD for Vaio then the only way to get it back is to carry out a full drive C:\ recovery back to factory settings.
WinDVD BD is not available for download - only updates to the original software can be downloaded - and it cannot be installed from your recovery discs. Due to licensing reasons it can only be installed as part of the Sony OEM software installations.
computers are a bit complex. IS it easy to restore disc C. Maybe i stick to dvds
What model Sony Vaio do you have?
Hi Corries11,
The recovery process should be fairly easy enough to follow..
If you let us have your Vaio model, as Blencogo mentioned, I'm sure we could supply with a guide..:smileywink:
Hi-i have tried to rescue bluray myself but no joy. My Vaio model is VGC-LN2M Its taken hours and hours
