I am in desperate need of recovery discs for my vaio VGN NR21J, I have had to get a new hardrive, but never made recovery discs when I first got the laptop. I cannot seem to type in my serial number online to find out who to contact to order some.....does anyone know what I should do? who I should contact? How much it will cost? or if I can do it any other way?
I look forward to any information!
Solved! Go to Solution.
The phone number for the UK are listed below..
Within guarantee period - 0870 240 2408
Outside guarantee period - 0905 0310006 (0.35£/min)
If you still have a problem after contacting support please let us know..:smileyhappy:
Hi TommyNeale,
You can purchase a set of recovery disc's from Vaio support..
To find contact details for Sony Vaio support click on the following link:Vaio support
Then under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch, followed by Out of Warranty Service.
And finally select Phone Support..
Thanks Thalamus_
I have tried this process numerous times to obtain the number, but for some reason as much as I try to enter the serial number (b) it just wont let me, i can type in the first 8 digits in serial number (a) without a problem, do you know what I should do to correct this?
Cheers,
TommyNeale
Hi TommyNeale,
If you let me know what country you are in, I'll let you know the number to call..:smileywink:
Cheers thalamus_
I live in England, thanks for all the help, hopefully I can sort this soon!
