increase of cpu tempature with second hard disk
ano102
since I have installed a second hard disk, it seems that the temperature on the processoris higher !
for information I have a addtionnal 512 Mo ram.
is the powersupply able to handle the second hard disk and the ram ?
the power is only 270 W !
the case of sony vaio RX 402 is so small that it is almost impossible to add fan to ventilate the case ?
where is it possible to install it ?
if anybody have experience on this problem ?
thanks for answer
kee-lo_
The PSU should be able to handle the new hard disk.
