Is there a docking station compatible with vgn-fz21z?
profile.country.el_GR.title
jkiriako
I'm looking for a docking station for my laptop, vgn-fz21z, but the ones I find are compatible with the newer vaios. Can anybody help?
Regards,
Ioannis
Hi Ioannis,
The FZ series does not have the docking station connection plug on the bottom - so it cannot connect to a docking station.
The only one you can use would be the VGP-UPR1A which is a USB connecting docking station with limited functions.  Have a look here: -
http://www.amazon.co.uk/Sony-VAIO-USB-Docking-Station/dp/B00144IVNO
You can probably find one if you Google: -
http://www.google.co.uk/search?q=VGP-UPR1A&hl=en&tbs=shop%3A1&aq=f
:slight_frown:
