odbc32.dll file not found!
LynneMcK
VGN-FZ21E, getting error message odbc32.dll file not found, can't use itunes or external hard drive, can anybody tell me if there is anywhere safe I can download this file from?
You should find a copy of the file on your Vaio.  Look in C:\Windows\i386\odbc32.dl_
1.  Click Start -> "All Programs" to view the complete list. Click "Accessories" to  open a sub-menu that includes the "Command Prompt" option.
2.  Right-click "Command Prompt" and click "Run as administrator."
3.  Type
expand -r c:\windows\i386\odbc32.dl_ c:\windows\system32\odbc.dll
and press Enter.  You will get a message confirming that the file has been expanded, renamed and copied to the System32 folder.
4.  ALTERNATIVELY Type
sfc /scannow
This option instructs sfc (System File Checker) to scan all protected operating system files and repair all files as necessary.
I would also run a Virus scan - just to be sure!!
I would not recommend downloading DLL files.
:wink:
3.  Type
sfc /scannow
:wink:
LynneMcK
Thank u, that worked a treat, no error messages, I can now use my itunes, external hard drive and bluetooth usb.
much appreciated :slight_smile:
