jumping cursor
franster2000
jumping cursor
My cursor keeps jumping when I am writing to another place in the text. I have the 'tap off when typing' which  seems to be the usual advice to correct this problem. Any ideas? It's really annoying.
It's a Viao VPCEB4E4E just over a year old, with windows 7. Just started doing this.
rich912
Hi frankster2000,
As you say that this has happened only recently try a Windows restore back to a date that it was working as expected. Otherwise try deleting and then reinstalling the original touchpad driver.
http://www.sony.co.uk/support/en/product/vpceb4e4e
Rich
Go n-éirí an bóthar leat
franster2000
thanks rich, will try that. F
