keyboard damage
stubarclay1
keyboard damage
I have spilt tea over the keyboard to my vgc-v2s and having switched it off and waited for it to dry out I am unable to establish connectivity. the battery icon flashes constantly. I am assuming that the wireless sender is damaged and wondered if this is an easy repair or if another keyboard would be best.
The windows diagnostic says the device is working properly but clearly it isn't . The separate mouse was untouched and works fine. :slight_frown:
kee-lo_
When this happens you should really take the battery out and let the bay dry out too.
Think you're going to need a new keyboard. Speak to VAIO-Link about that.
