I have started received a "Hard disk failure predicted on your harddisk" message when i boot. I guess this tells me that my hard disk is headed for doom. In any case, i have been mulling over a capacity upgrade for some time now.
Which hard disk should i go for. I am unable to find a make or model number or anything that i can google/ebay for.
- Mskadu
How about the Hitatchi Travelstar range? They're pretty good, and they use less power.
Have a look at the six reviewed HERE.
Your K115 accepts any ATA notebook drive with the standard dimentions 100 X 60 X 9.5 mm and you need the ATA (not SATA) version.
Or 2.5" if you're an imperialist
