lost info
jen1749
lost info
need to find voltage for a old laptop so i can order a new charger there is no lable and nothing under battery eny help please thanks jen
rich912
Hi Jen,
You are quoting the chassis number. Have a look on the lower right hand side of the screen surround for the correct model number – you will probably find it is a VGN-AW21xx.
If this is the case it will be DC output 19.5V, 6.15A, 120W. Model number VGP-AC19V16.
Rich
Go n-éirí an bóthar leat
10 REPLIES 10
rich912
Hi Jen,
If you let us know the model number of the notebook someone may be able to help.
Rich
Thalamus.
Champion
Hi jen1749,
welcome to Questions & Answers..:smileyhappy:
You should be able to find the volts & amp information on the underside of your old charger..:smileywink:
If you can not find the information on your old charger let us know your vaio model & we may be able to find the info for you..
jen1749
i dont have an old charger just the laptop. its an old hand me down,
The vaio model number is - PCG-8141M
product key is -
GMTOQ - JQBQ9 - JGKK9 - JHD8Y - WHWGK
rich912
Hi Jen,
Rich
jen1749
thanks for that the number is vgn-aw21m you can tell i know a lot about computers thanks
rich912
You’re welcome Jen:smileyhappy:
jen1749
hi there i am back needing more info, emailed  the charger shop and he saya next to the 19.5 there will be 4.7 or 3.9 thanks jen
rich912
Hi Jen,
That will be a universal power adaptor and with an amperage output of either 4.7 or 3.9 it is not suitable for your model.
Did you have a look at the link that Blencogo provided?
Rich
