The topic says it all really. What is the maximum size of hard drive I can fit into my PCG-GRT916V? Also what sort of drive would I need to buy?
Thanks for any help/advice offered.
Mark
Hi Mark,
As long as you buy an ATA Drive (NOT SATA), it should work in your GRT916V.
Some older Vaios do have a limit in the BIOS - you could check by tapping F2 when you see the VAIO logo on boot-up - but I think your model is modern enough to have no limit.
Have a look at THIS LAPTOP HDD REVIEW which recommends the 160 GB Seagate Momentus 5400.3 and gives details of other makes and their benefits/weaknesses.
EDIT: I have just noticed that you may have to Register with PC Pro to see the reviews. I find this worthwhile as they send a monthly free e-mail newsletter with all the latest news and info and their site is full of reviews and new product specifications.
