I have just reinstalled my complete machine, and I can not update 1 driver. in de devices the PCI driver is not installed correctly. I've tried all the driver from the update cd. no succes. I have a vaio SZ2H/B.
can anybody help?
Patrick
Try this. Copy your drivers folder from the CD to the desktop. Uninstall your PCI driver from Device Manager and reboot. Point the found new hardware wizard to C:/desktop, then let windows sort it out, which it should do. No need to find the actual driver. Windows will do that for you.
