Memory Stick Duo Adaptor MSAC-M2
TedBear
Hi...I just bought a new 4GB Memory Stick Pro Duo (I had a 265 Mb which came with my Vaio). With it came a Memory Stick Duo Adaptor MSAC-M2. Problem is I don't know what the adaptor is for....can anybody educate me please? :slight_frown:
davemee
There are different size memory sticks, you'll find that Sony Ericsson phones and PSPs take a smaller size. This is a sleeve adapter, which lets you fit the smaller card in the larger slot.
Thanks for the code - I need a replacement and I didn't know what the product code was!
TedBear
Thanks Dave, I found mine at Amazon.co.uk, but actually bought it from digiplay_uk via Amazon, I couldn't find any reference to the adapter on the Sony or the Vaio site
