Hi Community!
I have a Sony Vaio FW51ZF/H.
1. Does anyone know if the installed WIFI Adapter (Intel 5100 AGN) is mini PCI-E or half mini PCI-E??
2. Did anyone try an Broadcom WIFI Adapter in his FW5xxxxx series???
thx in Advance!!
regards Herzdrache
Solved! Go to Solution.
I think you will have to look inside to be absolutely sure but the second hand FW-Series card being offered on eBay here: -
http://cgi.ebay.co.uk/SONY-VAIO-VGN-FW-SERIES-WIRELESS-WIFI-CARD-E178682-/310239015296
looks like a Half-Mini size.
http://www.intel.com/Assets/PDF/prodbrief/319981.pdf
Hi Blencogo!
Thx for the fast answer!
well I think so too!!
regards
Herzdrache
p.s. as soon as I opend my Laptop, I'll post an Update just for confirmation 🙂
